ANAN-7000DLE and 8000DLE
This is a read-only sub-forum. If there is some documentation that you would like to see posted here, please PM or email a moderator.
Postby w-u-2-o » Sun Apr 09, 2017 1:39 pm
Schematics are not publicly available at this time. They are, however, available upon request. Please contact Apache Labs directly to obtain them.
DE-9F 9-pin Rear Panel Accessory Connector Pinouts
Postby w-u-2-o » Sat Aug 26, 2017 9:08 pm
1-GND
2-OCREF
3-OC6
4-OC5
5-OC4
6-OC3
7-OC2
8-OC1
9-OC0
Orion Mk II J16 Pin-outs
Postby w-u-2-o » Fri Dec 15, 2017 2:19 pm
On the Orion Mk II boards, J16, the IDC type connector on the board used to make connections to the rear panel connectors, is identical to the equivalent connector on the 100D and 200D, with one exception:
In the 7000, or on 8000's manufactured starting Dec 2017, Pin 10 is no longer ground, it is now "BUFF_OUT", and is intended to be used with EER type amplifiers (not that there is any firmware that currently supports this).
Return to “User Guides, Schematics & Other Documentation”
