Angelia (ANAN-100D) Protocol 2 test pilots: please check in
Postby w-u-2-o » Wed Apr 17, 2019 11:59 am
The P2 firmware for the 200D and newer radios seems to be shaping up in to a stable beta very nicely (thank you Rick N1GP!!!) Now we need to put a closer focus on the next oldest hardware, the Angelia card in the ANAN-100D.
Please let us know what firmware versions work, 11.7, 11.8 or 11.9, what versions don't work, or if none of them work for you.
This information will be critical to the development of a production version that does work for the Angelia.
Thanks & 73,
wa1oxt
Re: Angelia (ANAN-100D) Protocol 2 test pilots: please check in
Postby wa1oxt » Wed Apr 17, 2019 12:59 pm
Anan 100D ,SW ver. 2.6.4 ,FW ver.11.7 works . Rx,Tx, and PS work great.
FW ver .11.8 failed , When power button pushed 100D would start but no Rx,Tx,display. Many LAN dropouts .
FW ver 11.9. Rx, Tx work , PS inop. PS erratic ,will not correct. No LAN dropouts.
oxt.
n1gp
Postby n1gp » Wed Apr 17, 2019 6:53 pm
Hey Folks,
I've made a couple of Angelia (100D) FW images to try with various timing changes.
Please give them a try and let me know here which if either work best for you.
Best to load them with the Bootloader.
https://www.dropbox.com/s/zin81513mjunfbn/Angelia_Protocol_2_v12.0_pre1_5270.rbf?dl=0
https://www.dropbox.com/s/ryj9f6n6z6xmuuk/Angelia_Protocol_2_v12.0_pre1_4070.rbf?dl=0
Tnx,
-Rick / N1GP
ZL2XG
Postby ZL2XG » Wed Apr 17, 2019 7:54 pm
I have an early 100D (2014) only mod is the improved 10MHz TCXO.
Have been running Thetis with Ver 11.7 f/w for some months. Just installed Ver 11.9 f/w and Thetis Ver 2.6.4. All OK except:
1) Frequent short RX audio dropouts accompanied a a short (error?) message in the middle of the line below the display. The message are in the format "Seq =>nn" The nn number changes, the most recent one I have seen is 32.
2) The new QSK button on the CW sub menu is greyed out. So far no TX testting except for using the TUN buttom - which triggers a tune up carrier as expected.
Will be happy to answer any questions..
73, ZL1BOE/ZL2XG
Postby w-u-2-o » Wed Apr 17, 2019 8:35 pm
Please report on the two verson 12's posted above (try both).
wa1oxt
Postby wa1oxt » Wed Apr 17, 2019 9:13 pm
Intel 980x, 6 core ,12 threads, Nvida Cuda.
Anan 100D feeding a EB-104 300wt amp @ 50vts.
power output @ 160 watts.
Interesting !
Both work with PS.
What is interesting is that the IMD of ver 12/5270.rbf ....PS is much better on the 5th , 7th , 9th and up.
Ver 12/4070.rbf works also , but the IMD with PS on the 5th , 7th , 9th is not as good as ver 12/5270.
The IMD on the 3rd with both is abt the same.
Having said that , there are some harmonics within the passband with 5270 @ a 2T of 700/1900hz.
In any event , you have solved the PS problem in a timely manner.
Thank you very much for your effort's.
oxt
P2 ver 12,5270.PNG (594.34 KiB) Viewed 7833 times
P2 v.12 ,4070.PNG (557.89 KiB) Viewed 7833 times
wa1oxt
Postby wa1oxt » Wed Apr 17, 2019 9:39 pm
Correction.. my hardware is a 100d motherboard feeding an EB-104 300 watt SS amp !
Sorry for the error.
oxt
BrianLloyd
Postby BrianLloyd » Wed Apr 17, 2019 11:46 pm
73 de Brian, WB5BL (was WB6RQN)
dl2hbj
Postby dl2hbj » Thu Apr 18, 2019 7:20 am
I have tried both versions, with none of them I was able to receive or transmit. Only noise as if no antenna is connected.
Went back to Angelia_Protocol_2_v11.7_7-15-18.rbf and all works fine again.
This time I could use the Programmer instead of the Bootloader.
73, Jan
DL2HBJ
Postby w-u-2-o » Thu Apr 18, 2019 3:18 pm
Both Brian and Gary have been successful with
https://www.dropbox.com/s/zin81513mjunf ... 0.rbf?dl=0
@ZL2XG: it would be really good to know if that same version runs on your Angelia.
BREAK
@dl2hbj, Jan, what programmer are you referring to? The P2 programmer?
dl2hbj
Postby dl2hbj » Fri Apr 19, 2019 8:57 am
Scott, I used the P2 programmer.
I checked the Angelia_Protocol_2_v12.0_pre1_5270 again, which again doesn't work.
Would it be helpful if I made my database available?
73, Jan
DL2HBJ
ZL2XG
Postby ZL2XG » Fri Apr 19, 2019 11:50 pm
I tried e Angelia_Protocol_2_v12.0_pre1_5270 and it proved highly unstable.
The second ver 12 refused to load properly.
So, back to Ver 11.9 for the moment.
Chris ZL2XG
Postby w-u-2-o » Sat Apr 20, 2019 12:36 am
Jan,
If you haven't tried it already, I recommend reloading with the bootloader just to see if that makes a difference. The P2 programmer is not 100% reliable with the firmware we've got right now, i.e. when the firmware is struggling to make timing part of that struggle may affect P2 programmer.
Chris,
Thanks for the report!
VA2EY
Postby VA2EY » Wed Apr 24, 2019 5:39 pm
(Thetis V2.66)
-From Protocol 1 V 5.9, using HPSDRProgrammer_V2_nopcap 2.0
Firmware V 11.7 OK
-Using HPSDRProgrammer Web to Firmware
V 11.8 no power on, and unable to reuse HPSDRProgrammer Web. (see attachments)
-using HPSDRBootloader to
V 11.9 no RX, no TX Seq=>40
Angelia_Protocol_2_v12.0_pre1_5270, unstable, no RX and vary 0 to 60db with dummy load
Angelia_Protocol_2_v12.0_pre1_4070, no TX, no RX, Seq=>43, overflow and underflow problem on VAC
fail v11.8.PNG (92.95 KiB) Viewed 7597 times
n1gp
Postby n1gp » Sun Apr 28, 2019 4:17 pm
I believe I found the issue causing the antenna switching not to work.
Also I made some timing adjustments. If you can please try both of these and let me know
which works better.
EDIT: see further below...
EDIT2: see further2
https://www.dropbox.com/s/9ln9a1gcs3kb2kl/Angelia_Protocol_2_v12.1_pre1_5070.rbf?dl=0
https://www.dropbox.com/s/bquh66e9njma4y4/Angelia_Protocol_2_v12.1_pre1_5171.rbf?dl=0
(further below :) )
If you haven't tried the two above try this one first, if not please try as it is working best for me:
https://www.dropbox.com/s/sxq3vi32vy1ph3h/Angelia_Protocol_2_v12.1_pre1_5670.rbf?dl=0
(further2)
This image is the most stable so far, calling it a night on this one. Please check for Seq=>xx errors, PS, and
Diversity:
https://www.dropbox.com/s/agnso28woff4kyv/Angelia_Protocol_2_v12.1_pre1_5770.rbf?dl=0
Tnx
-Rick / N1GP
VA2EY
Postby VA2EY » Tue Apr 30, 2019 7:53 pm
Thetis v2.6.6 and HPSDRProgrammer_web_v0.2.7
v pre1_5070
RX ok no SEQ=>
RX + Diversity SEQ=>2 Diversity non fontional
TX ok no SEQ=>
TX + PS SEQ=> 2 + feedback level, no correcting
v pre1_5171
some missing communication in RX & TX
RX SEQ=>8 41 40, with some click noise
TX SEQ=>41 1 11 9
PS green, but some missing communication
Diversity ok but some missing communication
v pre1_5670
rarely RX SEQ=> 8 32
Diversity OK
TX SEQ=> 8
PS correcting but SEQ=>8 32 42
v pre1_5770
rarely RX SEQ=>2 8 32
Diversity ok
TX SEQ=>2 8 10 42
PS correcting
wa1oxt
Postby wa1oxt » Wed May 01, 2019 5:25 pm
Homebrew SDR.
Anan 100d Motherbd feeding 50vt. EB-104 300wt SSA @ approx 160 wts.
FW results
1. SW ver 2.6.7/FW ver_12.1 pre1 .5070
results ...PS-2 stable , inband IMD .
no seq issues.
2. SW ver 2.6.7/FW ver_12.1 pre1 .5171.
results ...PS-2 stable , less inband IMD , Xmit noise floor lower
no seq issues.
3. SW ver 2.6.7/FW ver_12.1 pre1 .5670
results ...PS-2 unstable , erratic corection,more
no seq issues.
4. SW ver 2.6.7/FW ver_12.1 pre1 .5770
no seq issues.
End result....
SW ver 2.6.7/FW ver 12.1 pre1.5170 works best here.
SW 2.6.7_FW-12.1 pre1-5670.PNG (615.94 KiB) Viewed 7388 times
SW 2.6.7_FW-12.1 pre1-5171.PNG (603.9 KiB) Viewed 7388 times
SW 2.6.7_FW-12.1 pre1-5070.PNG (605.24 KiB) Viewed 7388 times
wa1oxt
Postby wa1oxt » Wed May 01, 2019 5:34 pm
SW ver 2.6.7 with FW ver 12.1 pre1.5171.
Anan 100d feeding 50vt. EB-104 300wt SSA
2x3cx1500's @ 67 DBM.
oxt
SW 2.6.7_FW-12.1 pre1-5171..5k.PNG (261.9 KiB) Viewed 7386 times
wa1oxt
Postby wa1oxt » Wed May 01, 2019 5:56 pm
Homebrew SDR Platform.
Anan 100d Motherbd feeding a 50vt. EB-104 SSA with Homebrew pair of 8877's
Stable output with SW ver 2.6.7 / FW ver 12.1.5171 @ +67dBm.
Results ....
PS.2 AmpView attached.
Main GUI attached.
oxt
SW 2.6.7_FW-12.1 pre1-5171._@ +67 dBm output.PNG (261.9 KiB) Viewed 7383 times
AMP VIEW_SW 2.6.7_FW-12.1 pre1-5171..@ 67 dBm.PNG (26.53 KiB) Viewed 7383 times
n1gp
Postby n1gp » Thu May 02, 2019 12:33 am
Tnx for the detailed results of your tests guys.
It feels like we're converging on something that works within a variety of hardware.
I'm not sure why it seems harder to bring the Angelia in to a general consensus of
working well with P2 like the Orions. There's always variables such as the fact it's
running the net HW at a Ghz rate stressing current sensitive fuses which are rated differently
than the Orion. Also the quality of the supporting network infrastructure for certain users
may have something in play. We have only a few Angelia (100D) users reporting so far.
Still zeroing in on a good timing that fits all.
n1gp
Postby n1gp » Sat May 04, 2019 10:55 pm
Guys,
Please try this out and report back, if you would. Working OK here on my Angelia: no Seq errors, solid PS, solid RX2, solid diversity.
The major difference with this one is that it should hold its timing over a wider temperature range.
https://www.dropbox.com/s/9upj7vx5ji3os49/Angelia_Protocol_2_v12.1_pre2.rbf?dl=0
and this one
https://www.dropbox.com/s/0xxbh524r2pqi96/Angelia_Protocol_2_v12.1_pre2_5550.rbf?dl=0
Tnx,
-Rick / N1GP
wa1oxt
Postby wa1oxt » Mon May 06, 2019 6:26 am
Installed PC2 ver 12.1 pre2.rbf.
No seq issues over the past 24hrs.
PS is stable and correcting .
Buffer size/Filter Size set to max.
No audio dropouts.
The fuse issue on this Anan 100D motherbd is not an issue as yet.
I will try the other rev 2morrow
oxt
settings_PC2_ver 12.1pre2.rbf.PNG (29.21 KiB) Viewed 7244 times
12.1pre2 @67dbm.PNG (339.35 KiB) Viewed 7244 times
VA2EY
Postby VA2EY » Mon May 06, 2019 10:18 pm
Thetis v2.6.7
v12.1pre2
RX SEQ=>2,8
diversity ok
TX SEQ=>2, 10
Correcting does not work correctly
v12.1pre2_5550
RX OK NO SEQ
TX OK NO SEQ
Diversity OK NO SEQ
PS NO SEQ Correcting does not work correctly same problem as v12.1pre2
Feedback green OK but correcting vary black and green (while feedback is green)
in french...
le CORRECTING passe de vert à noir en alternance, pendant que le feedback est vert
wa1oxt
Postby wa1oxt » Wed May 08, 2019 5:00 am
Eval:
Thetis 2.6.7_PC2 _v12.1_pre2_5550.rbf
Anan 100D SDR Project.
Static IP addr from computer to Anan 100D.Project
UR 22 audio sound device (USB interface)
Audio via VAC -1
VMB (Voice Meeter Banana) set to 96kc/1024
VAC 1 set to 128/96kc
DSP SSB (Filter/Buffer size) RX_TX set to 16384/1024 .
Results.
1. No Rx/TX seq errors from 192kc- 1.536mHz (F/W setting).
2. PC2 (this ver5550.rbf)) stable from 192 -1.536mHz.
3. Few audio dropouts via VAC 1.
4. APD (Pure Signal) correcting and stable from 1.8mHz. - 29mHz.
5. Rx cal on the mark from 1.8mHz. - 29mHz. down to >145 dBm @ a filter width of 100hz.
6. IMD (3rd) @ 52dBm approaching -80dBm,
7 IMD (3rd) @ 67dBm approaching -65dBm.
Tests were run on Xmit from 52/62/67 dBm into a 68dBm 50 ohm load .
Rx calibration via a Rigol signal generator (DG4062) with additional Mini-Circuits attn's.
Tnx for your effort's
oxt
wa1oxt
Postby wa1oxt » Wed May 08, 2019 3:23 pm
Few audio dropouts mentioned in my last post.
After reading Scott's suggestions regarding the Resampler.
Problem solved by tweaking the Resampler.
Tnx Scott.
Attached pix of results @ 67 dBm.
oxt
Resampler tweek..PNG (335.19 KiB) Viewed 7104 times
wa1oxt
Postby wa1oxt » Wed May 08, 2019 7:22 pm
After a few more hours of Test & Measurement , I must say that both
PC2 pre2 5550.rbf / Thetis 2.6.7 are stable with my 100D SDR Project.
Optimizing the Resampler along with the aid of AmpView and the Rigol test equipment ,
I was able to tweak the bias on my amp for the best linearity and the least correction from APD (PureSignal).
Results was an IMD of -65 @ 67dBm output....outstanding outcome.
AmpView is a very powerful tool when running an analog amp (tube's) with adjustable bias an tuning.
ADP (PureSignal) now is the best than it's ever been !
AmpView results have been good in the past , but this results is over the top !
I've moved off ProTools to exercise the Audio Suite in Thetis , running just a standard profile , the audio reports
have been very positive.
Xmit EQ, VOX/DE and CFC work great.
Tnx guy's for a job well done..
lots of fun.
oxt
Results with latest PC2.PNG (370.76 KiB) Viewed 7083 times
Postby w-u-2-o » Wed May 08, 2019 9:57 pm
Thanks for all the feedback, Gary!
Joe-W4WT
Postby Joe-W4WT » Thu May 09, 2019 6:08 pm
Hi Gary,
I wonder which way you adjusted your bias to improve the IMD? I found that by increasing the bias on the PA in my Anan some time ago the IMD without PS running improved from the -20's to the -30's. This also resulted in an improvement with PS running. If I recall correctly, I changed the bias from 2 amps to 2.5 amps.
I haven't tried this with my Amp yet. It runs dual LDMOS devices. Maybe I should give it a go. I typically see mid to high -50's with it on most bands now.
Joe W4WT
wa1oxt
Postby wa1oxt » Thu May 09, 2019 8:40 pm
You can e-mail me @ wa1oxt@yahoo.com.
Don't want to move off the subject here.
oxt
Segrest
Postby Segrest » Tue May 14, 2019 1:29 am
Hi Rick,
I finally broke down and loaded Protocol 2 into my 100D today. The released version 12 file was a mess. The 12.1_pre2 file kept me from rolling back to Protocol 1. And the 12.1_pre2_5550 convinced me to continue running Thetis.
With version 12 the noise floor was bouncing around and hovering around -60 on the spectrum display.
With version 12.1_pre2 the floor dropped to around -90 and stabilized.
With version 12.1_pre2_5550 the floor is sitting at around -150 and quiet as a lamb.
He attached screen shot is 80M a minute or 2 ago.
Bob
KO2F
