10 or 10E
Posted: Thu Apr 26, 2018 7:36 am
by GM8GIQ
Question came up in conversation, can you tell a 10 from a 10E without opening the box ?
Is it possible ?
chuck...
GM8GIQ
Re: 10 or 10E
Posted: Thu Apr 26, 2018 2:31 pm
by W1AEX
Hi Chuck,
I believe you can identify whether it is a 10 or a 10E by looking at the firmware version in the Hardware Config menu tab of OpenHPSDR. The ANAN-10 firmware will be in the 3.x series which is also used by the ANAN-100 rigs. The ANAN-10E firmware will be in the 1.x series which is also used by the Anan-100B rigs. This assumes that recent firmware has been loaded into the rig you are looking at.
Re: 10 or 10E
Posted: Thu Apr 26, 2018 2:33 pm
by AB2EZ
Chuck
If you turn the 10XXX over you can tell if it is a 10E or not. A 10E has a small slide switch in the center of the bottom cover. The 10 does not.
Stu
