ANAN-7000DLE Update
The word from the top!
administrator
Re: ANAN-7000DLE Update
Postby administrator » Mon Nov 27, 2017 11:53 pm
Hi All,
We have shipped limited quantities to both HRO and Gigaparts as well as our EU Distributors,
All preorders should be fulfilled within the Next two to three weeks, thanks for your patience!
Abhi
WA2DVU
7000 operation WOW
Postby WA2DVU » Tue Nov 28, 2017 1:20 am
My 7000 arrived this afternoon - have it hooked up and is working fine. You will be impressed with this rig! 73, Bill, WA2DVU
w4kcn
Postby w4kcn » Tue Nov 28, 2017 3:58 am
HRO called this morning. 7000 should be here tomorrow.
spinomaly
Postby spinomaly » Wed Nov 29, 2017 4:53 am
Received mine this morning direct from Apache. SDR is completely new to me. Had some issues connecting which turned out to be the bootloader switch on the bottom that had been moved. W5WC quickly helped and I was connected.
Dr. Loren Betts
W6VH
Jim
Postby Jim » Sat Dec 02, 2017 2:43 am
Got mine today from HRO and have it working fine. Took me a little while to get it going I didn’t expect the switch on the bottom to be set to boot loader, something to check if it doesn’t startup for you right away. I did a little head scratching for about a half hour.
Operation appears to be fine but have noticed the front panel has no lettering below the three 1/8th jacks and the LAN plug. So no MIC under left jack, no HEADPHONE under the
middle jack, no KEY under right jack along with no LAN under the LAN Plug. It looks fine other than the lettering.
I sent of photo of the front panel to the dealer and I was told it was forwarded to Apache Labs. Hey! I could have a rare valuable piece of gear here!!!!
Bottom line operation is fantastic.
73 de KE4WY Jim
gw0gei
Postby gw0gei » Tue Dec 12, 2017 4:34 pm
My 7000dle arrived from the uk dealer today after ordering on Saturday - got lucky I guess in using a dealer who had bought a few in. :D It has serial number 0004 on it and its still warming up at home after unpacking at lunchtime after a cold journey up from London to west Wales. I am looking forward to hooking it up to my lan this evening and trying it out on the hpsdr mrx ps software I installed at the weekend.
My radio has the lettering on the front ok.
No doubt I will be making even more use of this community shortly as I get to know the radio and the client software - I have straight from ssdr and a flex 6300, so hpsdr is all new to me.
Steve GW0GEI / GW9J
West Wales
Anan 7000 DLE
Jim
ANAN-7000DLE Update
Postby Jim » Tue Dec 19, 2017 3:33 pm
Well, we have had our Anan 7000dle for 19 days now with no issues, glitches or anything noted. As mentioned earlier I did receive mine with some silk screening absent from the front cover panel. Apache-Labs did send us a new proper front cover panel with all lettering and it's been installed and all is well. In fact, we just changed it out today.
Some have mentioned they felt the cooling fan was noisier than they thought it should be but I am hard pressed to hear it here on this radio
serial 0020. I do not find it objectionable at all. One thing, after hours of operation I can place my hand on the case and find it to be cool to the touch so cooling seems to be fine.
So far we are very pleased with this radio.
dl4zbg
Postby dl4zbg » Wed Dec 20, 2017 1:18 pm
Hello Jim,
can you please send me a recording of YOUR 7000 fan noise?
Volker
DL4ZBG
Ernie
Postby Ernie » Sat Jan 06, 2018 11:26 am
All,
What is going on with the 7000DLE radio production? I have had one on order with Gigaparts for several months now, and it's nowhere in sight.
Ernie
W2FMU
administrator
Postby administrator » Sun Jan 07, 2018 1:03 am
Hello Ernie,
The radios start shipping again early next week, the factory was closed for the holidays,
Abhi
Jason
Postby Jason » Mon Jan 08, 2018 2:57 am
Hi Abhi,
Do you have any distributors in S.E. Asia for the 7000DLE?
Jason
9V1AM
iw3fvz
Postby iw3fvz » Mon Jan 08, 2018 4:04 pm
i have 2 questions: (Anan 7000)
1) it's normal if I use the external ptt in CW mode the radio does not switch in transmission?
(openHPSDR switch in tx but the anan 7000 no...not hear relay switch)
with o without the "semi-bk"
2) again in CW, I noticed that sometimes if I switch in TX/RX via cat (ZZTX) (contest software),
sometimes back in rx but I do not hear the audio but the waterfall works fine.
Returning to tx and then rx the audio come back (or set VAC1 on/off)
Many thanks
Fabio
Postby NC3Z » Thu Feb 08, 2018 11:00 pm
Seems the US distributors are out of stock now. I wonder how many 7000's were shipped to the US in that first batch?
Return to “Apache Labs News”
