Anan 10-E remote operation.
cleanrf
Re: Anan 10-E remote operation.
Postby cleanrf » Sat Oct 28, 2017 5:00 am
Thank you for all your help Scott!!
cleanrf
Postby cleanrf » Sun Dec 03, 2017 9:44 pm
Just wanted to post an update. I have been controlling my station and using openhpsdr remotely for a few months now. Its works rather well. The only issue I have is with my record (transmit) audio being choppy and breaking up sometimes. I can see this happen as it happens on the screen of psdr. I have lowered my sample rate to 44100 with no change. Was thinking it might have been a conflict with the earlier issue of not being able to change 1 item to match 48000 sample rate used elsewhere in my audio chain. I would like to go lower than this but I seem to remember voicemeter banana will not allow any lower sample rates. I would think we should be able to get by with a sample rate that is double of the audio bandwidth we want to pass. I listen to an AM operator that uses RemAud to pass his audio from his vehicle through a cell phone connection to his flex station and he sounds phenomenal. Seems I read something somewhere Scott where you may have had bad luck with RemAud. I believe he only uses RDP when he needs to make a frequency change or an adjustment then logs off RDP to free up bandwidth. He talks about how his doing it on the amfone forum QSO section back in July of this year. His call is wa1qix (Steveqix) I am trying to find a way to pass the TX audio with less issues. The receive audio in my setup is flawless and I would think there is a solution to the TX audio. Any suggestions from anyone of a different way to pass the TX audio is greatly appreciated. I will try to get pics up once I get everything in its final resting place.
Postby w-u-2-o » Sun Dec 03, 2017 10:43 pm
Yes, I've only had bad experiences with RemAud.
Also, I do not seem to have the same problems you do with the transmit audio path. Mine always works 100%.
If you want to try something completely different, RCForb from http://www.remotehams.com/ is supposed to work exceedingly well. You could combine that with RDP just to peek at the panafall display. I haven't tried it myself, but I've been tempted. If I didn't already have everything working I sure would try it.
cleanrf
Postby cleanrf » Sun Dec 03, 2017 11:48 pm
I have been thinking of giving this a try. My current scenario is perfect 95% of the time.
A65BK
Postby A65BK » Thu Feb 15, 2018 5:19 pm
Is there a detailed description available to do Hpsdr remote operation using team viewer ?
I installed it and started trying. I get audio in my ipad, when I play a youtube audio. But not get SDR audio in ipad. I have VMB in my PC.
Can anyone who has tried it to help me further ?
Rds
Prem, A65BK
Postby w-u-2-o » Thu Feb 15, 2018 7:59 pm
Prem,
Not to my knowledge. I have not tried to use Teamviewer because it has much higher latency than RDP.
Perhaps someone else has done this?
