Sources for additional attenuators
Posted: Thu Jul 13, 2017 1:23 pm
You can buy a very nice kit from Mini Circuits, in either BNC or SMA form factor, that comes with a selection attenuators that can be put together in different combinations:
https://www.minicircuits.com/products/designer-kits.html
This is an example of one of the BNC kits:
https://www.minicircuits.com/pdfs/K1-HAT+.pdf
However, an even better solution would be a fixed 10dB attenuator combined with a 1 to 10dB rotary step attenuator. They are always lots of relatively inexpensive rotary attenuators on eBay:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xrotary+step+attenuator.TRS0&_nkw=rotary+step+attenuator&_sacat=0
That way you can dial in to a dB exactly how much additional external attenuation you want/need.
