w9mdb wrote:My new fav power supply is the Samlex line. They are the only one I've found so far that do NOT ground the 12V common line to the chassis.
See my QRZ page for my campaign to get manufacturers to quit doing the common ground and similar USB shield grounding problems.
Mike,
Unknowingly, you likely have your power supply's negative terminal and chassis bonded regardless of any such connection at the power supply. Once the supply powers equipment where there's a bond between the equipment's negative lead and chassis, you have an unavoidable bond -- and some of those bonds are long loops that also include premise AC wiring ground wires.
Typically, a shack's supply is providing power for all kinds of things, including 12V station accessories. Almost all accessories bond the negative terminal to the chassis.
Because of this dilemma, I would rather not have a long terminal to chassis loop. As such, I first bond at the supply. If any anomaly develops, I'll then try isolating at the power supply and look for any improvement, especially with hum or RFI issues.
In the past and when trying to solve some difficult hum and buzz cases, I've used separate supplies for rig power and accessories where the rig's chassis is isolated from the negative 12V lead -- and nothing else on that power supply.
