Ways to record WF for up to 24 hours
Posted: Fri Mar 11, 2022 2:50 pm
I'm looking for a way to record noise on a band. This is because I have a horrendous noise source that isn't there always. I suspect it is a pot farm or something else illegal ... hoping not the case. It does sound like PL noise and when on it completely wipes out 160 - 6M in that direction. But it is so clean turning on and off I suspect man-made.
So - looking to record the WF, narrow frequency range is fine - for up to 24 hours. Any suggestions? If it can be done using PSDR/VAC that would be great. If there is another app that can be loaded and run that would use the VAC line to do this.
I do have an RSP1A as well if there's no solution for Anan/PSDR.
thanks for any help with doing the recording. I'm set to go hunt for it using a 705 and a 6M DF loop... but since it is erratic at best I'd like to see what pattern, if any it has. When there it cycles on and off - off from 20 secs - 3 mins and its on for 2 - 7 minutes. It also appears to be distant as my 4 element 15 at 36' is much lower than the 6 element at 90'.
