ANAN-100 Open-Collector problem
Posted: Thu Oct 18, 2018 11:36 pm
I am having trouble getting the open-collector interface to work. Hopefully, just a setup problem. I have configured ANAN Ctrl for 160M - 6 M. I never see any voltage on any OC pin relative to OC reference. When I check the band data from my Yaesu FT-990 I see 5V on the corresponding band data pin, e.g., 20M is coded as 0101 (DCBA). 0 volts where 0 is and 5 volts for the 1s. I expected the same on the ANAN-100 but no joy.
My ANAN-100 is a recent build with the V24 amp board. I usually run with protocol 2 firmware so that I can us SDR-Console. I have the tried to configure open-collector with Thetis and OpenHPSDR (protocol 1) without success.
Thanks for any help.
Steve, KW7F
Steve, KW7F
