Page 1 of 2
IMPORTANT UPDATE/DO NOT USE: 7000DLE fan noise fix
Posted: Thu Dec 28, 2017 2:43 pm
UPDATE: please see the post from Sunday, 31 Dec, below. There is some danger in using this circuit, it is not recommended at this time.
John, KB1YD, recently came up with a brilliant method to fix the fan noise on the 7000DLE and gave me permission to post it here.
As you may know, the root cause of the problem is reported to be the PWM controller waveform. John reasoned that the old trick of using a snubber circuit to soften the edge rates on the PWM waveform might help. According to John, this makes his fan "as quiet as a mouse".
John very graciously provided this schematic:
Conveniently, the fan control circuit on the 7000DLE is arranged such that you can actually install this circuit without opening the case, as the external fan connector is wired in parallel with the internal fan:
If you try this and find that it works for you, please post here and let us all know.
Disclaimers: I don't have a 7000 and have not tried this for myself. There are no oscilloscope measurements of the resulting waveform nor any fan speed measurements either (yet). Do this at your own risk.
Re: 7000DLE fan noise fix
Posted: Sat Dec 30, 2017 7:54 am
by dl4zbg
Hello Scott,
just tried this mod "on the fly" (did not manage to get the right pins for the fan plug - they will arrive in within a few days). Reduces the "rattling" noise A LOT. Will report next year.
Thanks again
Volker
DL4ZBG
Posted: Sat Dec 30, 2017 2:59 pm
That's great, Volker!
If you are able to capture any waveform or fan speed/performance data associated with this modification, I'm certain everyone would find that invaluable. Right now there is not enough data to know if it is reliable and safe.
Posted: Sun Dec 31, 2017 4:44 pm
John has just reported to me that the snubber circuit is not fully compatible with the TC652 fan controller IC. It turns out that the TC652 implements a fan sensing circuit that will cause the fan to shut down until power is cycled on the radio if it thinks the fan is not turning. Refer to Sections 3.0 and 3.3 of the TC652 datasheet.
It would appear that the softening of the current pulses is on the edge of tripping the fault detection in the TC652. John reports that this is happening to him every few hours. This can be a dangerous condition as you may not hear or notice that the TC652 has stopped the fan and the radio could overheat. Use of this circuit is therefore not recommended at this time.
Looking at the TC652 datasheet more closely, it can be seen in Section 4.1 a method that the TC652 manufacturer recommends for reducing acoustic noise. It also refers to this application note.
Unfortunately, looking at the Apache Labs implementation, it can be seen that they attempted to implement this noise reduction method, but defeated the entire method by using a FET instead of a BJT as the switching circuit element. This also explains why the base resistor is shown as a 0 ohm resistor. Most unfortunate.
The question now is can a set of snubber characteristics be identified that reliably satisfies the TC652 sensing circuit while still providing enough softening of the PWM waveform to achieve a useful amount of noise reduction in a safe manner.
The other alternative is to replace Q7 with a suitable BJT and R77 with a suitable resistor in accordance with this application note.
Re: IMPORTANT UPDATE/DO NOT USE: 7000DLE fan noise fix
Posted: Mon Jan 01, 2018 5:04 pm
by dl4zbg
Thanks for the warning, Scott......
Please excuse me for not replying earlier but we weren't celebrating New Year's at home....
I have been using John's "rattlesnake taming circuit" for a few hours without problems, just after I have finished the connection of the 7000 to my MicroHam MK2R+. Just made a few QSOs on 80... However, the level of noise was greatly reduced, but the rattle is still audible.
I call in question whether Apache Labs will ever fix this (NPN transitor instead of FET). So as a true coward I will wait for the first volunteers to make the mod with the BJT HIHI.
Thanks again and Happy New Year to you and all Hams reading this post reply.
Volker
DL4ZBG
BTW: If you want to use DIG2 input for an external keyer (e.g. MicroHam), you have to enable DSP>CW> Checkbox IAMBIC. Took me some time to figure this out...
Posted: Mon Jan 01, 2018 11:27 pm
by K9RX
Volker,
Not sure if Scott is going to want to move this but - use DIG2 as an external keyer? Why would you put the radio in DIG mode to use it in CW? What am I missing? I DO have a microHAM Keyer II and I was not able to get N1MM+ to work driving the radio on CW ... not sure if this applies or not.
Posted: Tue Jan 02, 2018 12:17 am
Gent's,
Moving individual posts is a pain ;)
It's a great topic, though. It would be beneficial to all if you made a new topic in the keys and keyers sub-forum where future seekers of the same information would logically look for it.
Posted: Tue Jan 02, 2018 1:51 am
by David G
Man, what is it with Apache Labs and fans? :lol:
Posted: Tue Jan 02, 2018 4:17 pm
by dl4zbg
K9RX wrote:Volker,
Gary,
Scott is right. I will post the info in the keyer index.
I'm shure you know this:
http://www.microham.com/Downloads/MK2_N ... _Setup.pdf
I am using both the MK2R+ and the micro keyer II (for contest operation with our local team). Winkey operation works flawlessly with Win-Test and UCXLog. There are two ways of connecting an external keyer (like a straight key):
1) Front panel Keyer jack "Tip and Sleeve" : Checkbox DSP>CW "IAMBIC" OFF
2) Rear Panel RCA jack DIG In 2 : Checkbox DSP>CW "IAMBIC" ON (not mentioned in the User's Guide- I was a little surprised....)
Sorry for causing confusion
Volker
Posted: Tue Jan 02, 2018 9:25 pm
Has anyone tried their fan simply hooked up to 12VDC and running full speed? It might be quieter that way...
Posted: Thu Jan 04, 2018 7:14 am
by dl4zbg
Yes, Scott.
No rattle but the fan is loud at full speed. Abt. 7-8 Volts should be ok while using an external controlled fan. I will check this next time.
Volker
Posted: Thu Jan 04, 2018 12:32 pm
Good to know, Volker, thank you.
Posted: Mon Jan 22, 2018 3:48 pm
by W2PHL
After experimenting with different values, I settled on 10 ohms with 68uf. I haven't had the fan shutdown with these values. The circuit is pig-tailed on the external fan connector. Since the snubber components are located farther away from the fan, it's possible there is some inductance also affecting the timing. I'm using the original fan.
Phil
Posted: Mon Jan 22, 2018 8:26 pm
Keep a careful eye on that, Phil!
How's it sound? Much quieter?
Posted: Tue Jan 23, 2018 7:31 pm
by W2PHL
I'd say most of the rattle sound is gone. It is noticeably quieter but not silent.
Posted: Thu Jan 25, 2018 3:53 pm
by dl4zbg
Installed the new snubber circuit today. I agree with Phil. It works just like the one described previously.
The Indian Rattlesnake is not tamed but somehow appeased...... :D
Hopefully I have a little more time in the near future to try the internal fan on fixed speed.
Volker
DL4ZBG
Posted: Mon Oct 14, 2019 7:52 am
by DL5RBW
For those who already have a deeper insight in that topic - what happens if I disconnect the original blower? I understand that the PWM controller shuts down if a proper "load" is missing however operation of the radio is not affected.
That blower noise meanwhile is so annoying that I intend to hook up the original blower to an adjustable power supply and let it run at a speed that should be sufficient and still be more quiet than using the "elaborate" PWM circuit. I understand there is a certain risk however if the fan is loud enough to be heard but without this annoying sound like an "out of balance fan that touches the grating with one of the blades" I will still detect even with headphones whether the fan stops working or not. Plus I also always watch the temperature very close as the thermal management in the original design is less than optimum to say the least. I am also in the process to fabricate a duplicate of the upper cover plate with holes to take another 120mm x 120mm silent fan to support airstream thru the chassis. The bottom blower is way to weak to push enough air thru the aluminum plate and the small vent holes and slots on the back and top. Tests with additional small blowers mounted over the rear perforation didn´t make a big difference so a more radical approach with a second fan pulling the air thru the aluminium heatsink plate and out of the chassis is necessary.
Any objections other ideas or solutions that showed up meanwhile that I have missed?
73 Roger, DL5RBW
Posted: Mon Oct 14, 2019 6:28 pm
by dl4zbg
Roger,
there is (was?) a fan mod kit available from Apache Labs Support. I finally ordered and installed this mod (new fan running at fixed speed)....
Volker
DL4ZBG
Posted: Mon Oct 14, 2019 9:38 pm
by DL5RBW
Hello Volker,
thanks for the information. Is that a new fan and what was the mod? New fan and/or external circuitry? Is it more pleasant (i.e. normal fan like noise) and is cooling sufficient?
I will contact APACHE LABS SUPPORT and post the result here. It might be interesting to many.......................
73/Roger, DL5RBW
Posted: Tue Oct 15, 2019 8:21 pm
by dl4zbg
Hello Roger,
yes, it's a new fan from NMB running at fixed speed. I am happy with it. As far as I've been told, all higher serial numbers of model 7000 DLE were supplied with this fan.
Volker
Posted: Thu Oct 17, 2019 8:41 pm
by DL5RBW
Hello Volker,
just got an information from Apache Labs Support and they don´t know of any fan modification other than the "snubber network" which for reasons outlined above they do not recommend.
Was your modification an official one and where did you get it from? What did you do with the original fan and where do you power the new fan from?
Posted: Thu Oct 17, 2019 9:18 pm
by dl4zbg
LOL
I forwarded my mail exchange with Apache to your Mail account. Please take a look at the infos.
Volker
Posted: Sun Apr 04, 2021 2:08 pm
by N9HLL
I really Hate being "That Guy" to bring up a dead 2`ish year old thread....But someone`s gotta do it...
Has anyone come up with any better ideas concerning this stupid Fan......My only complaint
I got spoiled running the 10E for years with no fan......Even buried under the bench I can still hear the 7k
Just Curious..
Rick
Posted: Sun Apr 04, 2021 2:24 pm
If it's the PWM "rattle" that's bothering you, simply rewire the fan directly to 12V.
If it's the fan itself you might do a little better with a slightly quieter fan. Others will have to suggest what make/model to get, I can't guide you there.
If that's still not good enough then you will have to either a) alter the Orion MKII board to properly implement the circuit per the fan controller data sheet and the app note or b) do what I did, which is remote the entire station (see my qrz page). I love my remote station setup. There's absolutely no noise at my operating location (my second floor studio/office). No relays clicking, no amp fans, nothing.
Posted: Mon Apr 05, 2021 4:02 pm
by w3ub
I'll throw in my two cents. I had a blue faced 7000 and the fan noise seemed not bad to me. I got a new 7000 black face this past October, and the fan is 1)always on the same speed it seems and 2)extremely noisy.
I have it inside my closet and I can still hear it. Have not looked into it much, but it is the loudest fan out of any radios I have owned.
Doug
Posted: Mon Apr 05, 2021 7:39 pm
I put mine behind a sheetrock partition and it's much quieter in the shack now.
Posted: Fri Jun 04, 2021 12:02 pm
by DL8LAQ
w-u-2-o wrote:The other alternative is to replace Q7 with a suitable BJT and R77 with a suitable resistor in accordance with this application note.
Is there anyone out there who did this modification? How does it perform now?
I have got an 8000 on my bench and the owner asked me if I can do something to lower the fan noise.
The 8000 is using the TC562 controller!
Posted: Fri Sep 24, 2021 2:52 pm
by JJ4SDR
w3ub wrote:I'll throw in my two cents. I had a blue faced 7000 and the fan noise seemed not bad to me. I got a new 7000 black face this past October, and the fan is 1)always on the same speed it seems and 2)extremely noisy.
Doug
Doug,
I acquired a quiet fan made by Noctua, NF-A14 PWM Chromax (they are very popular with guys who make their own PCs) recommended to me by a good friend,, bought a connector, did some splicing and plugged it into the DC volt port on the back apron of my black face Anan 7000 DLE MKII that I acquired less than 2 months ago. It also featured two control lines for PWM but I am just using the 2 DC lines. Not that the Anan was very noisy to begin with but the external fan helps especially during rag-chew contacts or CW especially (digital modes too I wager but I haven't used those as of yet).
Best!
JJ
Posted: Mon Jan 16, 2023 3:21 pm
by KC1LKO
Excellent info on this thread.
I recently had to replace finals on blueface 7000 and took advantage to also replace the noisy constant speed fan (NMB)
I used this one: https://www.arctic.de/us/F8-TC/ACFAN00208A (I also have option to use the Noctua (which I have "in stock") while I experiment with the artic one). I put the temperature probe in the vicinity of the finals...
Good news: It is so quiet I need to look at the Anan lights in front to see if it is ON.
No bad news yet...
Concerns: I have yet to heat up the radio (did the PA adjustments too) enough to really see/hear that fan spinning fast. I tested it with hair drier and know for sure the TC works. I have installed a zigbee temp sensor (smartthings) inside which reports to me the temp on minute/hours/days form into my Smartthings hub/app to "keep an eye on it"
Discoveries: While doing the PA adjustments I notice that putting a carrier on 6M did increase the Fan speed considerably. This was not due to temperature so I was puzzled as I did not know the Anan had any form to speed up the fan... the two leads go straight to a power connector... any ideas?
Miguel
KC1LKO
Posted: Mon Jan 16, 2023 3:40 pm
KC1LKO wrote:Discoveries: While doing the PA adjustments I notice that putting a carrier on 6M did increase the Fan speed considerably. This was not due to temperature so I was puzzled as I did not know the Anan had any form to speed up the fan... the two leads go straight to a power connector... any ideas?
Most probably internal EMI affecting the Arctic temperature sensor.
