100D unstable frequency
dmalcolm
Postby dmalcolm » Fri Jul 30, 2021 11:41 pm
I use my 100D with WSJT-X. The wideband frequency display provided with WSJT-X shows what I interpret as frequency instability. It has the appearance of a low frequency sine wave (perhaps one or 2 hz) were changing the displayed frequency traces, which look like a signal waterfall. straight lines are normal. If anyone thinks they may have an answer, I can provide a screen capture. Too make matters more confusing, the problem is intermittent.
Dan - K4HSQ
Re: 100D unstable frequency
Postby w-u-2-o » Sat Jul 31, 2021 1:42 am
Please post a screen shot.
w9mdb
Postby w9mdb » Sat Jul 31, 2021 3:15 am
In the Audio tab under VAC1 Monitor do you have "Force" unchecked?
Try checking it.
I found the frequency to be unstable without checking Force
dmalcolm
Postby dmalcolm » Tue Aug 03, 2021 1:20 am
I just tried checking "force" and it certainly is looking better. Thanks.
Dan - K4HSQ
