DXtreme Station Log and Anan 7000 DLE MKII
qst
Postby qst » Fri Feb 10, 2023 8:04 pm
I cannot connect Anan 7000 DLE MKII to DXtreme Station Log. This logging program connects through OmniRig using CAT. I selected OmniRig Power SDR and Kenwood but there was no connection. Maybe you have any idea how to get Anan to cooperate with DXtreme Station Log? Do you need a pair of virtual ports for this to work?
73's
Slawomir
Re: DXtreme Station Log and Anan 7000 DLE MKII
Postby w-u-2-o » Fri Feb 10, 2023 8:22 pm
I am not familiar with DXtreme Station.
To make a connection between Thetis and Omnirig you will need to install and configure virtual serial cable software.
qst
Postby qst » Fri Feb 10, 2023 10:08 pm
Hi ,
I have created 2 virtual ports in Virtual Serial Port Kit. These are ports 19 and 20. Thetis CAT has port 19 and OmniRig has port 20. No connection. I don't know which rig to choose in OmniRig. I tried Kenwood 2000 and Power SDR. Maybe it's a matter of port speed setting? DXtreme only works with OmniRig.
Slawomir
Postby w-u-2-o » Sat Feb 11, 2023 1:02 am
I don't use Omnirig, either. Perhaps an Omnirig expert will chime in.
It should cause little difference, Kenwood or PowerSDR.
Try posting screenshots of all of your setup screens. Maybe something will be obvious.
