Release: OmniRigDisplay
Postby oe3ide » Tue Feb 22, 2022 6:23 pm
another small tool :-)
It displays data from Omnirig in a rig-style look. The following actions are implemented:
* MOX
* SPLIT
* Copy VFO A->B, A=B, B -> A
* Change mode
OmniRig Display.zip
(173.78 KiB) Downloaded 103 times
Currently only Rig1 from OmniRig is supported. On request I would implement a setup to select Rig1/Rig2.
On my setup I had to turn on "Allow Kenwood Al commands" in Thetis, otherwise MOX, Split, etc. didn't work.
Here also an optimized OmniRig INI-File for Thetis:
EDIT: updated Thetis.ini
Thetis.ini
(4.99 KiB) Downloaded 103 times
The tool may be more interesting for people with conventional rigs, but of course it can be used by anyone.
I made the software for a good friend with an Icom IC-7600. I thought maybe someone else could use it too.
