Simple Cat Control--How To (I am stumped)
Posted: Fri May 15, 2020 5:58 pm
by LarryW
Please watch the video showing what I have going on.
Rig 7000 (no internal pc)
I am trying to connect Cat control to Fldigi-- I think I have tried about everything I know and have come up empty handed.
Audio is great through Banana.
I have VSPE and created a pair but still not go.
I have created a video to possible be of help to others also getting there feet wet.
Link to video
https://screencast-o-matic.com/watch/cYhobqk2Ua
Larry
N7ZDR
Re: Simple Cat Control--How To (I am stumped)
Posted: Fri May 15, 2020 7:22 pm
by oe3ide
Hi Larry,
you need to select the rig-file (xml-file) in fldigi cat dialog.
I tried this https://sourceforge.net/projects/fldigi/files/xmls/sdr/ and it works. Just download the xml-file and put it into c:\users\<youruser>\fldigi.files\rigs. Then you can select this file in the cat-setup-dialog
73 de Ernst
OE3IDE
(still no anan-radio.. still on dry run ;-)
Posted: Fri May 15, 2020 9:19 pm
by LarryW
Thank You----
We got it up and running. I remember doing this for all the old Flex radios but I never seen anywhere on the forum here about loading this in. Maybe I will re do the video showing this important step in the process and put it on You Tube.
Regards
Larry
Posted: Fri May 15, 2020 10:51 pm
Not virtual audio related, moved to correct forum.
