Hi to all,
I have a problem with my Anan configuration with WSTJ-X program. Please help.
Slawomir
Anan 7000 DLE MKII & WSTJ-X
Re: Anan 7000 DLE MKII & WSTJ-X
Hard to help without knowing what the problem is , can you give some more information ?
Moving this to the digital mode subforum where it belongs.
Give us more info and we'll try to help.
Hi,I installed 4 Virtual Audio Cable-Muzychenko. In the Power SDR - audio-VAC setup I choose the MME driver. The input is only Line 3 and line 4 (VAC). The output is VAC 1, VAC 3 and VAC 4 (VAC). This is probably not correct. Which ports should I choose in input and ouput VAC1 audio setup in HPSDR?
Slawomir
Slawomir
Slawomir,
Please post some screen shots of your WSJT-X audio setup, PowerSDR VAC setup, and Muzy VAC setup screens. You can use the "Attachments" tab below the main editing window here to do that. Then we'll have a better idea of what's going on.
thank you for your answer. I have partially solved the problem. Audio drivers after the WIn 10 update did not work properly. I can already see 4 virtual cables in the HPSDR setup. But only you can see them when the MME driver is enabled. When I turn on the Windows WDM-KS driver, there is no VAC in the input and output window. Maybe this is a problem of the Muse VAC program. WDM-KS is also in the older version. I send screenshots.
73's
Slawomir
73's
Slawomir
- VAC2.jpg (816.8 KiB) Viewed 10634 times
- VAC1.jpg (989.02 KiB) Viewed 10634 times
- My VAC Config.PNG (194.43 KiB) Viewed 10634 times
Windows updates are known to damage noon-Windows sound drivers.
Uninstall VAC. Reboot. Reinstall VAC. Reboot. Then try setting it all up again.
Hi Scott,problem solved. By default, the new version of VAC Capture port and Render port is turned on "auto" I changed to Wave PCi and now everything works ok. In the Window WDM-KS driver in the input and output tab virtual cables are visible. Everything works ok.
Thank you for the advice. Best wishes.
Slawomir
Slawomir
- VAC-3PNG.PNG (38.76 KiB) Viewed 10607 times
after VAC configuration I turned on WSJT-X. The Wide Graph shows working stations, the reception level in the Ban Acitivity window is about 70% and there are no working stations. I have enabled CQ and correspondence can see my sign. A few people called me but I didn't see them in the window. I don't know what I did wrong in HPSDR or WSJT-X configuration. What can I check and change to correctly receive stations and work on FT8?
Slawomir
Slawomir
- PrzechwytywanieDLO-WSJT-X.PNG (2.45 MiB) Viewed 10587 times
Are you using anything to ensure your PC clock is accurate?
Hi, I solved the problem. I had to change Driver WDM-KS to MME and everything started to work properly. I don't know why WDM-KS doesn't work. Various configurations are shown on Youtube. Only MME works for me and I will leave it that way.
Greetings to all.
Slawomir
Greetings to all.
Slawomir
