ANAN 7000/8000 and MMTTY
DL5RBW
Postby DL5RBW » Sun Nov 25, 2018 2:51 pm
Does somebody run this combination (see subject) and could give an explanation of how it is set up? I am using PowerSDR mrx software and would like to also include my favourite nostalgia mode - RTTY!
N1MM according to other posts here is obviously working however I think that it is an overkill for a non-contester like me. A package with basic operation possibilities is enough for me in other words DXing and casual QSOs is all I need. Sure MMTTY offers much more than that but is probably the most basic software available these days. So far I was using a HAL ST-6000 converter and WinDSRTTY (DON´T laugh!) but I don´t think WinDSRTTY (which I am familiar with) is compatible with the ANAN.
Any suggestions or better solutions?
Re: ANAN 7000/8000 and MMTTY
Postby w-u-2-o » Sun Nov 25, 2018 3:01 pm
Are you familiar with virtual audio cable setup?
Are you familiar with virtual serial cable setup?
Those are the basic elements of integrating any digital mode software, including MMTTY.
Just trying to see if you are starting in the basement or on the first floor, so to speak.
DL5RBW
Postby DL5RBW » Sun Nov 25, 2018 3:28 pm
I am not familiar with setting up VAC however read the tutorial (don´t remember whether it was SDRzone or somewhere else) and also have the kind support of people who are familiar with setting up computers (although no hams). Me personally I am starting at the basement level................
So from your reply I take that MMTTY can be integrated and the question is "how"? If the answer is yes then I will continue with obtaining VAC and installing MMTTY. I just don´t want to run in the wrong direction with RTTY software that doesn´t work-
Postby w-u-2-o » Sun Nov 25, 2018 6:21 pm
MMTTY is probably the least friendly RTTY program. BUT the flip side of that is it is also the most adjustable, and has the best decoding of anything I've ever used. The other caveat on MMTTY is that it is so old that it will require you to set up a virtual serial port pair using relatively low numbered COM ports, preferably in the single digit range, e.g. COM5 and COM6, as it does not support COM ports numbered above 16 or something like that.
Fldigi is another very popular program. It supports a great many digital mode modulations as well as RTTY. It is more modern and easier to use. You can certainly install that as well, try it and see if you like it better. It will use the same virtual audio and serial cables you set up for MMTTY so you won't have to duplicate anything.
A couple of quick "whys", since we are in a foundational learning mode here...
Why VAC? Because there has to be audio passed bidirectionally between MMTTY and PowerSDR, and because otherwise you would have to install two physical sound cards or interfaces in your PC, assign one each to PowerSDR and MMTTY, and then make physical patch cables to wire them together.
Why virtual serial ports? Because it is via a serial CAT connection that PTT and VFO information is sent between PowerSDR and MMTTY, and because otherwise you would have to install two serial ports in your PC, assign one each to PowerSDR and MMTTY, and then make a null modem cable to connect them.
My VAC tutorial can be found here:
https://apache-labs.com/community/viewtopic.php?f=13&t=2655
As for virtual serial port software, there are three choices: com0com, VSPM and VSPE. The latter is not free, but it is my recommended choice given its superior stability. In any of them you need to set up a serial port pair, assign one of the pair in PowerSDR CAT setup, and the other one the pair in MMTTY.
I have no step by step guide for MMTTY, but that should be enough to make you dangerous. Certainly come back with any questions. Be prepared to post screen shots of your setup to aid in debugging any problems. Youtube can be helpful, although I could not find any MMTTY--PowerSDR videos that I thought were any good.
DL5RBW
Postby DL5RBW » Mon Nov 26, 2018 8:53 pm
thanks for your detailed reply. I am not focused on MMTTY but it was recommended by one of our local RTTY contesters. FLDigi was something I stumbled across as well and as you suggest it it may be the better choice. It also seems that it is updated in short intervals so it definitely is up to date.
Thanks also for the hint with the virtual serial ports for PTT and VFO info - I didn´t consider this but of course now as you mentioned it it makes sense.
I am not sure whether I got the right picture yet when it comes to "virtual audio transport" but my understanding is that the VAC is expecting a certain data format from PowerSDR on one side and gives out a certain data format on the other side that is accepted by FLDigi for the RX case? For TX the direction just swaps. This is just a crude approximation to keep the oversight.
Thanks for the link to your tutorial which I will study the next few days. Maybe I still have some questions..............................
Any preferred VAC software that you recommend?
Thanks - Roger
Postby w-u-2-o » Mon Nov 26, 2018 10:13 pm
If you can get over the elderly interface and the complex user interface, MMTTY is probably the best RTTY software there is.
You've got things coming together correctly in your head.
As per my tutorial, I greatly prefer Voicemeeter Banana. It is essentially a virtual mixing board, making it easy to meter and monitor your virtual audio connections. And, IMHO, it has a superior ability to mix and match drivers and sample rates, if required (but do endeavor to get everything running at 48KHz as per the tutorial).
Postby K9RX » Tue Nov 27, 2018 1:29 pm
I agree that MMTTY is a bear to set up and seems not to be as flexible as my previous and now once again current choice: MixW. I find the latter to be easier to setup, has a built in log and transfers contacts automatically to my logging program (CommCAT) and has a bandspread. After struggling with MMTTY I finally went back to MixW.
I know one reason why MMTTY is pushed is because it is the one chosen to be used with N1MM+. I don't know if I'll ever do an RTTY contest ... so for now that isn't an issue for me... but consider that in your decision.
Postby w-u-2-o » Tue Nov 27, 2018 2:17 pm
K9RX wrote:I know one reason why MMTTY is pushed is because it is the one chosen to be used with N1MM+. I don't know if I'll ever do an RTTY contest ... so for now that isn't an issue for me... but consider that in your decision.
It's also got a really great decoder, reliable and sensitive. I can't speak to MixW, but I've tested MMTTY against Fldigi and MMTTY is far superior.
Postby K9RX » Wed Nov 28, 2018 1:00 am
Yes - I have heard that MMTTY has a great decoder ... I've really not compared the two so I can't comment there only to say I've worked some pretty weak stuff using MixW ...
