Easypal
Posted: Thu Nov 16, 2017 3:48 pm
by therealboss
Has anyone here setup Easypal to work with their Anan?
I have an Anan200D and use it on FT8 and other modes along with HRD without any issue but can't get Easypal running, can someone share their settings.
EI7HDB
Re: Easypal
Posted: Thu Nov 16, 2017 5:02 pm
I don't run EasyPal, but if you post screen shots of both the relevant PowerSDR and EasyPal setup screens we can probably identify the problem for you.
What is not working? Audio? CAT control? PTT?
Re: Easypal
Posted: Thu Nov 16, 2017 5:08 pm
by w9mdb
I just set it up oh my ANAN 100 without any problem.
You need a 2nd com port pait to talk to so have to enable CAT+
Then you can Setup/Use CommPort (PTT CAT)
For example, I've got CAT2 enabled on PowerSdr on COM3, 38400,8n1.
A serial port pair form COM3/4
Then setup Easypal on COM4.
Seems to work just fine.
de Mike W9MDB
Re: Easypal
Posted: Sun Nov 19, 2017 9:30 am
by therealboss
Thanks for the reply guys, I have worked it out and now have it working.
Re: Easypal
Posted: Sun Nov 19, 2017 11:30 am
What was the problem, and the solution? Someone else might be searching for the same answer down the road. It would be nice if they could find it here.
