CAT command reference and list
Postby w-u-2-o » Sun Oct 08, 2017 7:18 pm
There is no truly up to date CAT command reference for PowerSDR mRX. However, you can use a combination of the following two documents to figure out 90% of your CAT questions:
1. The original Flex Radio CAT command reference for the legacy version of PowerSDR:
http://www.flexradio.com/downloads/powersdr-cat-command-reference-guide-pdf/
2. The file CATStructs.xml, located in the directory C:\Program Files (x86)\OpenHPSDR\PowerSDR mRX PS, contains a comprehensive list of all CAT commands that are currently supported in PowerSDR mRX. If the <active> tag is "true", then the command is supported.
DL8LAQ
Re: CAT command reference and list
Postby DL8LAQ » Wed Oct 17, 2018 6:50 pm
this link is no longer available.
73, Norbert
w9mdb
Postby w9mdb » Wed Oct 17, 2018 7:03 pm
DL8LAQ
Postby DL8LAQ » Thu Oct 18, 2018 7:48 pm
Thank you, Mike! :D
aa6rs
Postby aa6rs » Mon Apr 13, 2020 11:16 pm
I am new to the Apache Labs world and after using a SDR it would be hard to go back to a knob and dial radio. However it has been a struggle to get it all working.
I would like to get my 8000dle (using OpenHPSDRmRx v.3.4.9) working through CAT to my N3FJP logging program. Wish there was a fellow AL owner nearby a I need some serious hand-holding but hopefully a reader(s) of this forum can step me through the process.
Also at some point I would like to connect to my FLDIGI on the laptop for digital modes.
Appreciatively, Rich AA6RS
Postby w-u-2-o » Tue Apr 14, 2020 12:13 am
Rich,
Please start a new topic in this sub-forum. Call it "N3FJP setup", and we'll get you fixed up in a jiffy. We don't want to combine it with this topic.
