Predistortion on OM-Power amplifiers?
I2NOY
Postby I2NOY » Wed Jun 21, 2023 1:31 pm
Hi, is it possible to get a realtime attenuated signal (55-60 dB) from the output of OM-Power or others amplifiers that don't have the output connector carrying this signal?
Any market product available?
Many thanks.
Re: Predistortion on OM-Power amplifiers?
Postby K1LSB » Wed Jun 21, 2023 2:21 pm
There are any number of market products available, none of which interested me so I built my own 18K-ohm pure resistive sampler that connects directly to the SO-239 jack on the back of my amp.
Disregard the jumble of ancillary resistors and variable pots in the picture, that box was a prototype. The final circuit consists of the six 2-watt Allen Bradley 12K-ohm carbon composition resistors in a series/parallel arrangement that provide 18K-ohm of measured resistance. That arrangement allows PureSignal to function correctly at any power level from a barefoot 25 watts to full legal maximum power.
Postby w-u-2-o » Wed Jun 21, 2023 2:35 pm
I like the Xtronic units, but HRO never seems to be in stock:
https://www.hamradio.com/detail.cfm?pid=H0-015644
Apparently you are not aware that OM makes their own coupler :D
https://www.arraysolutions.com/index.ph ... t_id=14897
For new amp's OM offers this option:
https://www.arraysolutions.com/index.ph ... t_id=14891
W4WMT
Postby W4WMT » Wed Jun 21, 2023 3:24 pm
I can personally recommend this one made by a couple of retired Tektronix engineers. It's sort of expensive but built like it came from Tektronix. And for an extra $75 it will come with its own NIST certificate :-)
https://preciserf.com/shop/ddc545-dual- ... l-coupler/
Bryan W4WMT
Postby K1LSB » Wed Jun 21, 2023 4:33 pm
PureSignal doesn't need a directional coupler, so the extra money expended on one of those is wasted on PS.
AG5CK
Postby AG5CK » Wed Jun 21, 2023 10:28 pm
K1LSB wrote:PureSignal doesn't need a directional coupler, so the extra money expended on one of those is wasted on PS.
It doesn't need it to function, but can puresignal make more accurate corrections if only forward power is being sampled?
Postby K1LSB » Wed Jun 21, 2023 11:03 pm
Forward power should be the only thing that's being sampled and fed back to PS.
So, on reflection (pun intended) I guess your point is valid! :)
I2NOY
Postby I2NOY » Sun Jun 25, 2023 3:45 pm
Many thanks for any suggestion. ;)
Best 73s.
