Which DAC?
Posted: Sat Jul 29, 2017 9:37 pm
I know that when I take audio from the front panel or rear port of my 200D, that I'm using the DAC built into the radio's board. (Incidentally, is there any way to test the accuracy of this DAC, and where is the sample rate set?) If I'm using VAC, I know it uses the DAC of the interface I point Setup towards. For VAC1, this is the UMC202HD into which my mic, phones, and powered speakers are plugged. VAC2, however, points to lines 1 and 2 of Muzychenko's virtual audio cables and then to digital traffic software such as fldigi.
So here's my (other) question. When using M-VAC, is audio being piped directly to the receiving software at the sample rate shown in Setup>VAC2, without any other sampling?
Buck ko0y
Buck ko0y
