Heil ICM with Anan 7000DLE
NZ5F
Postby NZ5F » Thu Jun 17, 2021 12:50 pm
I have a question about using a Heil ICM with the Anan 7000DLE. Is it possible to use that microphone with the front microphone 1/8" stereo input. I got a good deal on a boom setup from a friend and just want to confirm that i can utilize it. If I can't use that microphone I would like to get a boom microphone for my setup. The deal comes with the boom setup and all the parts and pieces. Thanks for any advice on this topic,
Keith
NZ5F
Re: Heil ICM with Anan 7000DLE
Postby w-u-2-o » Thu Jun 17, 2021 3:05 pm
You can pretty much use any microphone you want with the ANAN. But the cable and connector has to be wired properly, and both the bias and mic boost settings need to be set properly.
The pinout for the ANAN mic connector is in the manual, and the settings in Thetis can be found in Setup > General > H/W Select and Setup > Transmit.
Bias on and boost off for a condenser mic like the iCM. The opposite for a dynamic mic.
Hardware options depend on how your mic cable is wired. Do not attempt to plug a mono connector into the stereo jack, it will not work right.
