PTT IN or DIG IN 1? R LINE IN and L LINE IN?
pa1hr
Postby pa1hr » Wed May 20, 2020 8:10 am
I have two questions concerning the rear panel of my brand new 7000DLE MkII (black).
I use the microHAM CW KEYER.
The KEY output of the CW KEYER is connected with DIG IN 2.
The PTT output of the CW KEYER is connected with PTT IN.
This works fine, but is it possible to use DIG IN 1, instead of PTT IN?
I understand that R LINE IN and L LINE IN are meant for connecting a soundcard for digital modes. Is this correct? Can I use them for other purposes too?
TNX and 73, Hans PA0Q.
Kind Regards,
Hans Remeeus (PA1HR/OE3JRC)
http://www.remeeus.eu
http://www.hansremeeus.nl
Communication is about people, the rest is technology.
Helmut
Re: PTT IN or DIG IN 1? R LINE IN and L LINE IN?
Postby Helmut » Wed May 20, 2020 8:26 am
Hallo Hans,
I have the CW Keyer and use only the key output - ptt is only needed, if you will use
it with other programs for a ptt-port in usb devicerouter.
The key-output of the keyer has to go on your anan (no photo of the black one - only blue one)
to the dig in2 as you did and without ptt it should key fine.
On my 7000dleMK2 with the big silver case there is TX-inhibit and CW-Key written on the two ports,
and you are correct the line-in L + R are for sound.
73, Helmut
dl9eri / oe9eri
pa1hr
Postby pa1hr » Thu May 21, 2020 1:15 pm
Thank you Helmut!
I will try only DIG IN 2 for the keyer, without PTT.
Another question: has PTT OUT on the ANAN the same function as DIG IN 1, but buffered on the DIG IN 1?
LINE IN L and R I will not need at this moment.
TNX and 73, Hans.
Kind Regards,
Postby w-u-2-o » Thu May 21, 2020 2:58 pm
pa1hr wrote:Another question: has PTT OUT on the ANAN the same function as DIG IN 1, but buffered on the DIG IN 1?
DIG IN 1 is an input. The current software uses it as a TX inhibit signal, as already mentioned above.
pa1hr
Postby pa1hr » Thu May 21, 2020 8:00 pm
Thanks Scott!
The manual is not very clear on these items.
73, Hans.
Kind Regards,
